Author Topic: Momo Steering wheel installation..  (Read 2102 times)
Robracer
« on: 15 July 2014, 15:18 »
Hi guy's, i got my hands on a barely used Momo S'wheel. But before i install it in my 97' golf gti. I'm worried about setting off the dreaded airbag warning light! I'm aware i need to disconnect the battery first. How does the momo wheel fool the airbag ecu into thinking it's still connnected?
Thanks in advance  :smiley:
Offline Foreveryoungaus16v
Re: Momo Steering wheel installation..
« Reply #1 on: 15 July 2014, 15:29 »
You put a really really small resistor in the 2 holes on the end of the air bag wire and it closes the circuit and then the air bag light will needed to be turned off with vag com. Do a search there are a few threads confirming which resistor works.
163 BHP (TSR POWER RUN)
Robracer
« Reply #2 on: 15 July 2014, 15:35 »
Cheers bud, i'll do a search
Offline LR5V
« Reply #3 on: 19 July 2014, 21:29 »
Something I that got me scratching my head when I did mine was the horn wiring.
The instructions dont say, but you will need to remove the slip ring off your existing air bag wheel.
I just picked the correct resistor up from Maplin, shoved into the connector with some insulation tape holding it in place.
Robracer
« Reply #4 on: 19 July 2014, 23:20 »
That also made me wonder, the horn wiring? What ohm resistor did you go for mate? Plus i'd solder mine to be safe
Offline LR5V
« Reply #5 on: 01 August 2014, 22:44 »
Sorry fella, not been on for a while
Iirc I used a 4.7 ohm one from Marlin.
Really no need to solder, the prongs hold in the yellow connector pretty well & the tape keeps it from shaking out + you can always go back to original easily
