Author Topic: Possible wheel bearings.  (Read 1537 times)
Offline GTiIVTurbo
« on: 14 July 2014, 02:46 »
When driving over 70mph in my 1.8t my steering wheel shakes uncontrollably. And this continues as I accelerate. It stops immediately as I take my foot off the accelerator. Is this due to the wheel bearings?
Thanks folks.
Re: Possible wheel bearings.
« Reply #1 on: 14 July 2014, 10:46 »
Have you had the wheels balanced ?
Offline matty james
« Reply #2 on: 14 July 2014, 11:01 »
sounds like track rod end/ball joints to me,had same symptoms and that was what it was.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline GTiIVTurbo
« Reply #3 on: 14 July 2014, 12:17 »
I'm just on my way to get the balancing done anyway so can rule that out if all is good with that.
Offline WadGTI
  • Golf GTI'er
« Reply #4 on: 14 July 2014, 12:19 »
Sounds like the wheels. Have you got much tread left on the fronts?
Offline GTiIVTurbo
« Reply #5 on: 14 July 2014, 12:22 »
Tyres are fine. As well is tyre pressure.
Offline WadGTI
  • Golf GTI'er
« Reply #6 on: 14 July 2014, 12:24 »
get the balance checked, then as matty said above, ball joint ends before looking at others.
I had wobble back a few eeks back, simple balance took the shakies away  :smiley:
Offline GTiIVTurbo
« Reply #7 on: 14 July 2014, 22:55 »
A simple balance was all it needed.
Thanks guys.
