Author Topic: Clear rubber tube - what is this?  (Read 2906 times)
Offline andrewparker
« on: 10 July 2014, 17:07 »
Hi all, I was having a poke around my GTD this afternoon and noticed a clear rubber tube hanging down behind the rear drivers side wheel. Does anyone know what it is for? I can pull on it and it appears to be hanging loosely from higher up on the car.
Current – Mk7 Golf R, Night Blue, 5dr, Manual / Mk7.5 Golf R, Indium Grey, Estate, DSG
Offline kevinm
Re: Clear rubber tube - what is this?
« Reply #1 on: 10 July 2014, 17:19 »
Could it be the drain tube for the fuel filler?
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
Offline phazer
« Reply #2 on: 10 July 2014, 17:20 »
Yep, it's the drain tube for around the fuel cap. If you open the flap you'll see the hole where the water runs, the pipe directs it out away from inside body panels.
« Reply #3 on: 10 July 2014, 17:22 »
Ah, that makes sense - cheers guys :smiley:
Offline adekil
« Reply #4 on: 10 July 2014, 17:46 »
So basically a Catheter for a car!  :whistle:
Current(2024): MK8 Golf R, Pure White, RV Camera & 19" Estoril Diamond Cut
