Author Topic: The age old power steering fluid query...  (Read 5458 times)
Offline Simeon
« on: 07 July 2014, 20:49 »
Right, I have already searched before anyone says anything  :tongue:
I have a 1997 mk3 tdi, which (according to receipts) had a new powersteering rack in 2009. The fluid in the system was the red stuff and the rack was peeing fluid, so I just had a horrible weekend changing the rack again.
Searched the web, green cap = green fluid. Got some on the shelf, great, banged it in but was a little short.
Mate went to gsf today for me to get another litre, but while the stuff he bought is green, it is a synthetic oil, whereas the stuff I have used is a mineral oil = me confused.
Can anyone tell me which on I need to be using, really don't want to bugger up another rack. Here are the ones in question.
Mineral - http://www.ebay.co.uk/itm/Febi-Power-Steering-Shock-Absorber-Level-Control-Fluid-Oil-1-L-06162-Bmw-VW-Seat-/310960482748?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item4866b069bc
Synthetic - http://www.ebay.co.uk/itm/2-x-1L-POWER-STEERING-FLUID-CHF-11S-HYDRAULIC-OIL-FEBI-BILSTEIN-/250995858521?pt=UK_Vehicle_Oils_Lubricants_Fluids&hash=item3a7084dc59
Thanks in advance :)
Offline boneybradley
  • Back in a Mk3...
Re: The age old power steering fluid query...
« Reply #1 on: 07 July 2014, 21:18 »
you need the second one in your link (febi 06161) which is mineral
Offline Simeon
« Reply #2 on: 07 July 2014, 22:18 »
Hmmmm, damn, I've put 6162 in it.
You say 6161 is mineral, but the bottle says it's synthetic?
My bottle of 6162 says mineral on it...
  • Back in a Mk3...
« Reply #3 on: 07 July 2014, 23:16 »
Sorry your are right 6161 is synthetic and 6162 is mineral, I should check my stock and what it says before I speak! (also recommended is 06161 for the mk3)
Offline Simeon
« Reply #4 on: 07 July 2014, 23:23 »
Ah OK, thanks for clearing that up. I'll flush it with 6161 then. Do you know if it will cause any damage running the mineral for a couple of weeks?
« Reply #5 on: 07 July 2014, 23:45 »
Yes it will damage seals etc plus will not mix, drain and flush asap.
Offline Simeon
« Reply #6 on: 08 July 2014, 00:37 »
Hmmm, Ok, I've not mixed them, its on the minimum mark on the dipstick. I'll get it changed as soon as possible but gonna be a couple of weeks :(
« Reply #7 on: 08 July 2014, 10:53 »
I would not risk it for a few weeks, you will cause damage.
Offline Simeon
« Reply #8 on: 08 July 2014, 11:27 »
What are the differences between the mineral and synthetic blends that will cause damage?
I'm interested as it took 4years for the red stuff to do a number on my last rack. From what I understand its all to do with viscosity, the red fluid being thicker thus building greater pressure and popping a seal?
« Reply #9 on: 08 July 2014, 11:57 »
Being the wrong grade or type of oil means it will not lubricate as it should plus being different types of oil means they will not mix.
