Author Topic: 20vt conversion advise/help  (Read 1683 times)
Offline b8enp
« on: 07 July 2014, 20:38 »
A bloke at works wrote his 20v Audi a4 off and offered it me at price I can't knock it back at just wondering if I'm to strip it what will I need to take of it,what other parts will I need to source it's going in an 8v digi and how big of a job would you say it is cheers Ben
Offline EsSeX dAn
Re: 20vt conversion advise/help
« Reply #1 on: 08 July 2014, 00:09 »
as its an a4 the engine will be longditudinal, which means you will need to get (mechsnically wise)
sump, inlet and exhaust manifolds from a transverse engine as a start. then youll want:
g60 engine mounts, mk3 diesel gearbox and shifter (this box will line up with your existing driveshafts) and some bigger stoppers, g60 280mm discs and callipers will do well if you want to keep it 4 stud. youll also want a corrado or passat hydraulic pedal box or a seat clutch actuator. then its a case of plumbing in your intercooler pipework.  i think thats it mechanically
then youll need the electrics side of things. youll need to get the immobiliser prorammed out of the ecu if you want to use your original clocks. then have a little read of this to find out what to cut and join to what http://www.clubgti.com/showthread.php?205887-OEM-management-wiring-1-8T-gt-Mk2-harness-install-FAQ
hope that helps!
i think i love you.....
« Reply #2 on: 08 July 2014, 10:55 »
Easier to start with a Golf tbh.
Offline b8enp
« Reply #3 on: 08 July 2014, 16:36 »
I've bin looking at the car today and to be fair it's to good to break think I'm gonna sell my van n keep the a4
