Author Topic: No boost wen driving and CHECK ENGINE LIGHT ON  (Read 2398 times)
Offline golffez
HI lads new on this site from ireland .I have a problem from the weekend i was trying to solve mt A/C PROBLEMS so i was tryin to find A/C relay while doing this i had engine running and took out relays in engine compartment fuse box and wen took one relay out engine shut off so put back in started fine no problems idle is fine but when i went to drive it later that day i found no boost from turbo in my mk 5 2005 gti and CHECK ENGINE light on,so i put on a vag computer and its telling me number <3 cylinder knock sensor> is gone so i rang vw dealer and they said very unusual as they never give trouble on them ,so i was wondering has anyone had a problem like this all information is greatly appreciated cheers paul .
Offline th3_f15t
Re: No boost wen driving and CHECK ENGINE LIGHT ON
« Reply #1 on: 07 July 2014, 20:41 »
So no other fault codes came up relating to other engine sensors? I take it you cleared all the faults and took it for another drive.
Don't mean to sound condescending, but did you make sure all relays were inserted correctly and properly after you completed your work?
Moving over to Flickr, sorry for the broken picture links!
Offline golffez
« Reply #2 on: 07 July 2014, 21:13 »
Na u kool yeh put em all back way tey were and wen went to drive just no boost in car and engine light on . i got up number 3 cylinder knock sensor tat all i getting . but engine is running fine no knocks or anything like this ,its as if the turbo was just switched off  :whistle: :shocked:
Offline th3_f15t
« Reply #3 on: 10 July 2014, 11:50 »
Chances are is a sensor has gone, the ECU will default to a limp mode to protect the engine and may explain why you're turbo isn't functioning.
Best bet it to replace the sensor and then see if the engine continues to incorrectly function.
Offline golffez
« Reply #4 on: 18 July 2014, 22:51 »
all srted lads was a burnt out relay not too pricey  :cool: :cool: :cool: :cool:
Offline markos
  • kämpfen und siegen
« Reply #5 on: 21 July 2014, 20:14 »
eh?
