Author Topic: Front parking sensor  (Read 2173 times)
Offline Aifer
« on: 06 July 2014, 13:57 »
Hi All,
I'm a new GTI MK7 owner and mine came with rear parking sensors only (including the visual graphs on the media screen). Considering installing front sensors only if they protect the front Diffuser/spoiler from touching a low sidewalk.
In other words, will they alert a low obstacle or just when getting closer to a wall.
Any experience guy?
Offline vidman2
Re: Front parking sensor
« Reply #1 on: 06 July 2014, 16:05 »
I have fitted sensors to the front of 2 previous cars and find that normally after market sensors only project straight ahead so would not pick up low kerbs ect.
However if you chose the mounting points carefully so the sensors pointed slightly downwards you would pick them up, the difficulty is that you would have no way of knowing if they pointed low enough, or even too low so they picked up the road surface, until they were fitted and then they could not be repositioned.
You would also need to carefully check over the gaps and accessibility behind the front bumper to determine where you could fit them and then wire them in to a switch on the dash.
2015 R DSG. Limestone Grey, DCC, Winter Pack, Tech Pack, Reversing Camera    plus   2013 Mk7 GTi DSG - Performance, Navigation, Winter Pack, DCC, Park Assist,
Offline mcmaddy
« Reply #2 on: 06 July 2014, 16:53 »
If you remove the front bumper you'll probably find marks where the factory fitted sensors go.
