Author Topic: New brakes foot flat to the floor :-/  (Read 3134 times)
Offline Mattyj
« on: 05 July 2014, 16:11 »
Just fitted my bbk and braided lines bleed brakes with a one man bleed kit till no more bubbles took for a spin foot goes flat to the floor :-/ guess it just needs another bleed but if not, apart from the unions not being tight any ideas?
Offline mustard
  • Mk7 R
Re: New brakes foot flat to the floor :-/
« Reply #1 on: 05 July 2014, 22:18 »
Air in the ABS Pump?
Offline mwad gti
« Reply #2 on: 05 July 2014, 22:34 »
Foot shouldn't go to the floor
Candy White 3 dr Manual 2012 GTi. Bought new.
DAB, Dynaudio, Kenwood Head Unit Upgrade, Private Plate,
Full Leather and Heated Seats
18" Shadow Monzas, luxury pack.
Colour coded side skirts and gloss black diffuser.
Offline Neil gti
« Reply #3 on: 06 July 2014, 08:07 »
I think you need to run the abs pump to bleed them properly ?
Get a VW specialist to bleed them or main dealer,
May be a silly question but have you fitted your calipers the right way up ? Bleed nipple to the top,
As some calipers off different cars have them fitted to right or left of the disc as you look at it, if the nipples are at the bottom it may trap air inside, and also the leading piston which is usually smaller will be on the trailing side,
I think a full fluid change at the dealer is only about £45
No need for up rated fluid, use the vag stuff that's all I use and never had a problem with it, if it's good enough for a Veyron it's good enough for a golf  :grin:
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline Mattyj
« Reply #4 on: 06 July 2014, 10:15 »
No bleed abs pump, calipers the right way up its spongy
Offline ajmoir36
« Reply #5 on: 06 July 2014, 20:08 »
Bleeding (normal):
Adhere strictly to work sequence when bleeding brake system.
–     Connect brake filling and bleeding equipment -VAS 5234-.
–     Open bleeder valves in specified order and bleed brake calipers.
1 - Front left brake caliper
2 - Front right brake caliper
3 - Rear left brake caliper
4 - Rear right brake caliper
Use suitable bleeder hose. It must sit tightly on bleeder valve so that no air can enter brake system.
–     Leave bleeder valve of each brake caliper open with bleeder hose fitted until brake fluid discharges free of air bubbles.
Subsequent bleeding
Carry out subsequent bleeding when:
t     brake pedal travel is too long or so-called »soft brake pedal«
t     in vehices with EDL, EDL/TCS or EDL/TCD/ESP a chamber in the brake fluid reservoir is completely empty. This occurs e.g. in the case of brake system leaks.
Subesquent bleeding requires the assistance of a second mechanic:
–     Depress brake pedal firmly and hold.
–     Open bleeder valve on brake caliper.
–     Fully depress brake pedal.
–     Close bleed valve with brake pedal held down.
–     Release brake pedal slowly.
This bleed sequence must be carried out 5 times per brake caliper.
Bleeding sequence:
A road test must be carried out after the brakes have been bled. When doing this an ABS regulation must be performed at least once.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Mattyj
« Reply #6 on: 06 July 2014, 21:12 »
Did see this mate when you sent it over cheers
Offline ajmoir36
« Reply #7 on: 13 July 2014, 11:30 »
You sorted them out yet?
Offline Mattyj
« Reply #8 on: 13 July 2014, 12:57 »
Think just need bigger master cylinder they work just a tiny delay on pedal travel
