Author Topic: 8v cat back on a 16v ?  (Read 1677 times)
Offline clancy
« on: 02 July 2014, 00:20 »
I'm after an exhaust system for my 16v, but second hand these don't seem to come up very often.  8v ones seem to come up more
I know yiu can't interchange parts, but my understanding is if you replace everything after the cat it's fine ?
Only thing is the 8v systems are designed at 50mm and the 16 at 55mm,  is that 5mm reduction really going to make a difference performance wise ? Or should I just what it out for a proper 16v system
Thanks for any help
MK3 GTI 16v
Offline tweed
Re: 8v cat back on a 16v ?
« Reply #1 on: 02 July 2014, 10:36 »
Ive never seen any test to see what happens with a 8v exhaust on a 16v or vr6 so cant say if it would make a difference, but why would VW go to the trouble and expense to fit a larger diameter exhaust if it didn't need it  :huh:
so dont fit it mate and weight for a 16v/vr6 exhaust.
« Reply #2 on: 02 July 2014, 13:54 »
It will build back pressure and you will lose power.
Offline clancy
« Reply #3 on: 02 July 2014, 14:10 »
Fair enough that's that then! Just getting impatient
Cheers for the replies guys
MK3 GTI 16v
Offline clancy
« Reply #4 on: 03 July 2014, 18:41 »
Am I right in thinking the scorpion systems are the same for 8 and 16v models,  both 55mm ?
MK3 GTI 16v
