Author Topic: loosing water  (Read 2145 times)
Offline andc1
loosing water
« on: 28 June 2014, 23:21 »
I'm loosing water our from the coolant tank. Seems to be coming out from the overflow bit. I've replaced the rank but to no effect . It flows out and runs out of water . Any ideas ?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: loosing water
« Reply #1 on: 29 June 2014, 08:42 »
Check all of your connections to the rad. Some times the old hoses perish and crack.
Offline Dalo Harkin
Re: loosing water
« Reply #2 on: 30 June 2014, 12:53 »
If it's coming from the overflow then its overheating or you are overfilling
Offline james2
  • No scammers please.
Re: loosing water
« Reply #3 on: 30 June 2014, 14:35 »
Head gasket proberly.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: loosing water
« Reply #4 on: 30 June 2014, 17:50 »
is there an overflow?
Offline andc1
Re: loosing water
« Reply #5 on: 07 July 2014, 18:38 »
Yes it leaks out of the over flow on the tank.
Offline andc1
Re: loosing water
« Reply #6 on: 07 July 2014, 21:21 »
How easy is it to change head gasket ?
Offline Ant1981
  • Feed me, prod me
Re: loosing water
« Reply #7 on: 08 July 2014, 07:54 »
Not that difficult, depending on how involved with cars and mechanical things you like to be. I ought to do a write up as I've replaced mine after I had the head off for a rebuild.
'09 Kawasaki Ninja ZX-6R
Offline Dalo Harkin
Re: loosing water
« Reply #8 on: 08 July 2014, 12:59 »
have you taken the top hose off the coolant tank and held it over the filler part and then started the engine, this will show the speed of the water being pumped around the system, and potentially any blockages if there are any.
I would guess yours is getting too hot and then coming out of the overflow, meaning its overheating, could be the water pump is shot but this will show in the above test because the coolant will be moving slowly
« Last Edit: 08 July 2014, 13:29 by Dalo Harkin »
