Author Topic: Sai removal  (Read 3370 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Sai removal
« on: 28 June 2014, 21:18 »
Going to remove the sai and all its crap, can someone explain what to do with other sh!t electrical bits and what not
AUM engine
Ive already done n249 bypass  :smiley:
« Last Edit: 28 June 2014, 21:45 by 1.8Tgolf_Chris »
Offline dom
  • Back in a Mk4
Re: Sai removal
« Reply #1 on: 28 June 2014, 21:55 »
  • Mk4 1.8t AUM
Re: Sai removal
« Reply #2 on: 28 June 2014, 23:10 »
Thanks dom appreciate ur help, Ive seen it before but find it rather over complicated  :undecided:
so basically i wont use the n112 valve any longer so therefore i run the vac straight of the inlet to DV and one line to FPR, then use 2x 10w 330OHM Resistors on both the electrical plugs then i can remove the that plate and small engine cover?
please correct me if im wrong
Offline dom
  • Back in a Mk4
Re: Sai removal
« Reply #3 on: 29 June 2014, 09:07 »
Yeah you've pretty much got it, you need a blanking plate for the side of the head where the combi-valve comes off, you also remove a load of hard lines, the corrugated pipe and obviously the pump itself.
Here is everything I removed from mine:
I also removed the carbon canister at the same time.
  • Mk4 1.8t AUM
Re: Sai removal
« Reply #4 on: 29 June 2014, 12:21 »
Cheers mate that is spot on, maybe ill do the carbon canister another time dont really know what it does
Offline Dalo Harkin
Re: Sai removal
« Reply #5 on: 30 June 2014, 08:36 »
I know it makes an annoying ticking noise  :laugh:
rip it out
