Author Topic: Traction warning light  (Read 2247 times)
Offline axlslash
  • appetite for destruction
« on: 27 June 2014, 20:16 »
Recently my traction light comes on now and then when driving, I have pushed the button to turn it off but it wont go off, after turning the engine off for 10 minutes an then back on, traction light is off again and enables me to switch it on and off again...but after about 10 minutes driving it lights up again an I can no longer turn it off, also noticed when driving the steering feels loose like the traction is off(this is before the light is back on). I have a 1.4 16v, looked around the engine for a maf sensor but cant find it as I have read that this can cause problems related to my traction problem, any suggestions?
/AxlSlash
Offline dom
  • Back in a Mk4
Re: Traction warning light
« Reply #1 on: 27 June 2014, 21:50 »
Have you scanned for fault codes?
Offline axlslash
« Reply #2 on: 27 June 2014, 22:01 »
yes i have no codes are showing up
Offline matty james
« Reply #3 on: 27 June 2014, 22:13 »
your maf should throw up a code-it always has done in expierence.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline axlslash
« Reply #4 on: 27 June 2014, 22:16 »
ill try and rescan to see if anything comes up
Offline matty james
« Reply #5 on: 27 June 2014, 22:22 »
does light come on when your excellerating -if so it could be your maf
Offline itavaltalainen
« Reply #6 on: 27 June 2014, 23:08 »
what are you using to scan for fault codes? don't say one of the cheap obd2 scanners...
could be issue with something else... abs sensors etc
Offline matty james
« Reply #7 on: 28 June 2014, 17:02 »
then abs light would also be on .
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #8 on: 28 June 2014, 17:59 »
My golf recently done this turned to be the MAF changed it now its ok
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
Offline axlslash
« Reply #9 on: 28 June 2014, 20:36 »
useing this
 http://www.ebay.co.uk/itm/like/220860299070?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108
i have used this on my golf wen i had fault codes.. works fine just wont find the problem to the traction light comeing on and yes it come's on wen i do excellerating some time around 40-50mph
