Author Topic: Mk4 Golf Gti AGU not boosting  (Read 2346 times)
Offline nealy1572
« on: 23 June 2014, 21:13 »
I. Sorry if been asked before but my 2000 mk4 *AGU not boosting ive changed 3 split pipes
Ive had codes read and say coolant temp sensor
Would this cause issue im getting sensor at weekend
Any help or info or anybody local to leeds 9.to come and give there view would be appreciated
« Last Edit: 25 June 2014, 07:12 by nealy1572 »
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Mk4 Golf Gti AUG not boosting
« Reply #1 on: 24 June 2014, 00:16 »
Yes more than likely. Is the problem temperature related? Like is it boosting fine when cold? They are a common failure and if the ecu is getting a bad signal it will go into limp mode with reduced boost.
Offline nealy1572
« Reply #2 on: 24 June 2014, 17:40 »
Changed sensor but still same no boost  ar still drives  :angry:
Offline viperjsy
« Reply #3 on: 24 June 2014, 19:53 »
have you checked the dv and all the boost hoses
« Last Edit: 24 June 2014, 19:56 by viperjsy »
Offline nealy1572
« Reply #4 on: 24 June 2014, 20:14 »
Yeah all look ok it has a forge rec valve fitted
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 24 June 2014, 20:30 »
dodgy MAF can cut the boost on the AGU
Offline nealy1572
« Reply #6 on: 24 June 2014, 21:27 »
Ok ill try another maf ill get one ordered thx for reply
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Mk4 Golf Gti AGU not boosting
« Reply #7 on: 25 June 2014, 19:51 »
you need to do some logs really, find someone in your area with VAG COM and go for a blast as it might show something
Offline nealy1572
« Reply #8 on: 28 June 2014, 18:08 »
Thanks all for replys i removed turbo all vains were damaged amd had 3 large cracks where it bolts to down pipe so gona brake car
Offline james2
  • No scammers please.
« Reply #9 on: 28 June 2014, 19:23 »
I would get a second hand turbo from scrapyard ,the ko3s and have it mapped. You will get more power than the agu turbo.  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
