Author Topic: pedal snapped on golf anni/brake fault  (Read 3033 times)
Offline jake-w07
« on: 20 June 2014, 16:37 »
Had an absolute nightmare today something snapped off the clutch pedal so clutch hit the deck. Right in the town centre couldnt drive anywhere managed to push it to a 2 hour car park and left a note in. Anybody had this problem mechanic cant look at it til monday morning so im without my car and its stuck on a car park miles away from my house. Any help would be appreciated i dunno what to do
« Last Edit: 27 June 2014, 10:57 by jake-w07 »
Silver Golf GTi 25th Anniversary 1.8T - Milltek Non Res Catback - 3" Downpipe & Decat - Forge 007p - ITG Cone Filter - Custom Remap
Offline rockmonkey69
Re: pedal snapped on golf anni
« Reply #1 on: 20 June 2014, 16:53 »
I think I read a while ago that it's a bracket that snaps
Offline jake-w07
« Reply #2 on: 20 June 2014, 17:08 »
Hmmm will try google cheers
Offline Nino
« Reply #3 on: 20 June 2014, 18:16 »
Taken from http://uk-mkivs.net/topic/2672-clutch-pedal-swap-out-repair/
Quote
Further to the plea for help regarding my little clutch problem, I've fixed it and here is
the how-to.
Note:- This How-to would be of benefit if you ever need to remove your clutch master
cylinder, as during my forum(s) search I noticed that a master cylinder failure is quite
common. Apart from the hydraulic side of the operation, most of the work is in the drivers
footwell and would be as follows. The master cylinder retaining nuts look like they are
accessed from the footwell side.
Anyway, my problem was that I was driving home, Wifey & Kids in the car.... went to change
gear, pushed the clutch pedal in and "BANG".... No clutch.
Posted Image
The above piccy shows what went bang (I used this piccy in my initial cry for help so please ignor the bit that asks if there's another clip).
Posted Image
The above piccy shows the broken pedal insitu prior to me removing it. Note:- The white clip
I refer to was never found..... it probably went boing and could be currently anywhere in the
footwell area... no doubt resting somewhere where it'll either rattle or cause some other
horrid problem.
To remove pedal (assumes you know a bit about 'cars' and how they work etc..... even so, this
IS NOT A NICE JOB.... A real fiddle):-
1, Remove lower trim from footwell area.
2, Release over centre spring. I used a long screwdriver and pushed on the white nylon end
piece until the spring popped out. There are some handy little recesses on the white bit that
will prevent your screwdriver slipping off.
3, Undo and remove the pivot nut and then wriggle out the bolt. (note I say wriggle as it
hits the steering column on it's way out.... it's fiddly but it does come out. Further Note
:- I fitted the bolt from the other side to avoid this problem on re-assembly).
4, If your master cylinder pushrod is still in position, you will now have to release it. The
ball is held in place by a white nylon holder..... press in the tags to release it. (see
piccy)
Posted Image
Above piccy shows my 'repaired' pedal and the location of the 'tags' that you need to press
in to release the master cylinder pushrod.
Posted Image
The above piccy shows how things are laid out in the car.
Refitting........
5, Fit new pushrod ball carrier to pushrod (65p from VW !!) I fiddled and swore for a while
but eventually managed to fit it with needle-nosed pliers. It will 'click' in place and will
NOT come off again if you've done it right.
6, Struggle to put pedal back in car.....Engauge pushrod / carrier into box section on pedal
first before you put the pivot bolt back in (remember bolt from the other side....)
7, .......Now the tricky part, the over centre spring. Can't explain it to well in text but
look at the piccies below. Where it fits you'll know from when you took it out. This is the
toughest part of the whole procedure, it took me ages. (If you do use the cable tie method,
remember to cut them to release the spring AND BE CAREFUL !
Posted Image
Posted Image
JOB DONE !!!
I got.....
Frustrated
'Sore' fingers
Carpet burns on my elbows...... Ooo-err (you'll understand if you have to do this)
Hope this helps if you ever need it.
Good luck
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline brewey
« Reply #4 on: 20 June 2014, 18:19 »
It's not difficult per say. More fiddly and frustrating. You need someone with very small hands along side you!
2000 1.8T ARZ - OEM+
Offline jake-w07
« Reply #5 on: 20 June 2014, 18:48 »
Cheers boys got a fax for the parts but tps cant get em till monday morning at earliest, so gonna try scrapers tmoro morning
Got tickets for cumbria vag on sunday, gonna be gutted if i miss it my first ever show! :(
Offline brett
« Reply #6 on: 21 June 2014, 20:50 »
I had this the other month wasa ballache to get back in as not the comfiest position to work in.Luckily I got the pedal welded up at work so was only without the car for a day
Offline jake-w07
« Reply #7 on: 21 June 2014, 20:58 »
I got hold of a pedal assembly from the breakers and fit it today wasnt to bad a job actually, so i will be going cumbria vag :D
Offline jake-w07
« Reply #8 on: 27 June 2014, 10:57 »
Since fitting the clutch pedal assembly i keep gettin stop brake fault service manual and flashing hand brake sign goes off straight away though and ive no faults coming through on my code reader, bled the clutch and topped up the fluid when i fit the pedal assembly. My fluid level is still right to the top aswell i keep checking
Any ideas people ? Seems like one thing after another atm haha
Offline Adam
Re: pedal snapped on golf anni/brake fault
« Reply #9 on: 27 June 2014, 17:31 »
Brake switch
Down Hill From Here.
