Author Topic: Remote central locking-drivers door sometimes not unlocking  (Read 1864 times)
Offline Therusterman
As the title says, anyone have any pointers? At the moment I can usually unlock the door using the key fob and if this doesn't work use the key-but this sometimes takes a few cycles of locking and unlocking.
At the moment its an intermittent problem and doesn't appear to be affecting any of the other doors or the boot.
Offline itavaltalainen
oem central locking or retrofit?
oem remote fob or retrofit?
first guess would be vacuum leak in door frame bulk head.
As far as I know its OEM central locking, has a Toad after market full closure alarm fitted.
When you say door frame bulkhead, do you mean where the rubber boot runs between the door frame and door?
Offline cjgti
Re: Remote central locking-drivers door sometimes not unlocking
« Reply #3 on: 01 October 2014, 12:27 »
I have this very same problem. I was told it could be because of having a weak battery? Does that sound like something that might be causing it?
