Author Topic: Chip and stainless exhaust, your advice please.  (Read 4829 times)
Offline general_piffle
Re: Chip and stainless exhaust, your advice please.
« Reply #10 on: 19 June 2014, 12:42 »
^ PM sent :)
Anyone know how I find the correct ECU number to get the right chip? Thanks.
Offline Foreveryoungaus16v
« Reply #11 on: 19 June 2014, 14:56 »
Have a look on your ecu and message the guy on ebay. He is very helpful and knows his stuff. He will send you the chip which is specifically for your ecu. If you have a 16v you can easily install it yourself.
« Last Edit: 19 June 2014, 15:16 by Foreveryoungaus16v »
163 BHP (TSR POWER RUN)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #12 on: 19 June 2014, 22:23 »
The push in type ABF chips can be swapped in about 15 minutes they're that easy.
Offline bigberty101
« Reply #13 on: 20 June 2014, 13:40 »
The chip will alter ignition timing and fueling,power delivery should be smoother,the rev limit may be slightly higher depending on the program,mpg can also increase when driven sensibly,gains can be anything upto around 7 bhp with just the chip
the ignition timing cant be altered on standard management, or so im lead to believe.
Offline bigberty101
« Reply #14 on: 20 June 2014, 13:41 »
i think all simens ecu's are push fit chips and all bosch ecu's need to be socketed or soldered in
Offline Len
« Reply #15 on: 20 June 2014, 20:32 »
You will be lucky to get 2 or 3 bhp from any chip! The exhaust no gain at all.
I do have the Rolling Road graphs to prove this!
www.sas.org.uk
www.the-ace.org.uk
« Reply #16 on: 20 June 2014, 20:50 »
Yeah thats right. Only reason I changed my exhaust was that I got a good deal on a Jetex otherwise I would have kept it until it started to blow,
Offline Screech16v
  • MK3 20vt AGU
« Reply #17 on: 20 June 2014, 23:16 »
The chip runs more advanced timing over stock.Tbh even with a gain of 7bhp,it wont feel much different as the torque you gain is very little 3-4 nm
