Golf mk5
RNS510 straight fit in to a 08 gti?
Topic: RNS510 straight fit in to a 08 gti? (Read 2429 times)
damien010685
16 June 2014, 22:18 »
Hi guys away to buy 1 with an antenna etc are these a straight fit for a golf mk5 GTI 08? or do they need coding?
bacillus
Re: RNS510 straight fit in to a 08 gti?
17 June 2014, 08:41 »
It's a straight swap as you should already have a compatible canbus gateway installed in that 2008 model.
It does need a coding tweak in the installation list so the system knows you have a nav unit but the unit should work without issue in spite of not doing this.
Without traction power is nothing!
damien010685
17 June 2014, 10:26 »
Cool and te other option is I use my pioneer double din what fitting kit do people recommend to use?
dubber36
Forum addict
17 June 2014, 16:12 »
It's all very nice having an OEM radio, but if you want Bluetooth, ipod, usb connections as well, they are all add ons that you'll need to buy. Most aftermarket units have these as standard.
damien010685
17 June 2014, 16:48 »
Yeh I have a pioneer unit but what kit do I need to fit it
th3_f15t
17 June 2014, 17:02 »
Most likely a wiring adaptor and a facia mount to fill the gaps around the edges of the unit.
Moving over to Flickr, sorry for the broken picture links!
Golf mk5
