Author Topic: vagcom question  (Read 1596 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
vagcom question
« on: 15 June 2014, 16:18 »
Whenever I have scanned my car I get the same faults repeatedly. There are door lock modules, window motors, and few other things saying "intermittent voltage". Battery is fully charged and fuses are all clean with no corrosion plus everything works fine?! Not sure what else to check for as this is all it says to check on vagcom site?!
Anyone else had these faults thrown up and how did you fix them?
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline rio_gti
Re: vagcom question
« Reply #1 on: 15 June 2014, 16:38 »
Do you clear the faults after you scan?
You have to go into each modual desperately then press clear codes
Offline Perryd84
Re: vagcom question
« Reply #2 on: 16 June 2014, 08:49 »
Yeah I cleared them a while back but they came back on the last scan!?
Offline matty james
Re: vagcom question
« Reply #3 on: 16 June 2014, 13:08 »
if everthing works ok ,just leave em on.
mk3 gti"s and vr6"s,present a silver mk4 anniversary on adjustable coilovers.
Offline Perryd84
Re: vagcom question
« Reply #4 on: 16 June 2014, 14:48 »
That's what I have done but just worried that something might pack up if I didn't do anything about it!?
