Author Topic: car starts then cuts out.  (Read 2843 times)
Offline sharki786
  • GOT BOOST??
« on: 14 June 2014, 15:45 »
As above. The vr starts then cuts out. It defo is the immobliser problem. Is there a way around it by disabling the immobliser? I have the chip and ecu matching. Do i need the black box that sits behind the clocks?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline xAntiVenxm
Re: car starts then cuts out.
« Reply #1 on: 14 June 2014, 17:16 »
Haha same problem as mee!!
Offline itavaltalainen
« Reply #2 on: 14 June 2014, 18:52 »
what's the issue with immobiliser? does it not recognise key or is there any fault stored in it?
do you have a second key that works? if another key works get a new chip and program it into immo
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 14 June 2014, 19:57 »
Turns out that i am missing the transporter box so will have to wait AGAIN for the guy to send it lol.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 14 June 2014, 22:22 »
My old transponder (behind the clocks) wont work with thr new chip & ecu??
*****MK4 GTI T*****
« Reply #5 on: 15 June 2014, 19:37 »
What do you mean with transponder, the immobiliser box?
Transponder is a little thing in your key.
You can remarry your existing immo box to the 'new' ECU. For that you don't need login code iirc.
And you can keep using your existing keys.
Offline sharki786
  • GOT BOOST??
« Reply #6 on: 15 June 2014, 21:27 »
ok i have the vr chip (transponder) whats the little black box behind the clocks just above the clutch pedal?
I have the vr6 ecu
i didnt get that black box behind the clocks
so how do i remarry immo box to the ecu?
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 17 June 2014, 14:10 »
That seems like its to do with the mk4 not mk3
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 18 June 2014, 21:58 »
Ok fitted the box behind the clocks and still same. Its comming up with key blocked by immobliser p1570 tried both chips and still same.
so who will deimmobilose the ecu for me?
*****MK4 GTI T*****
