Author Topic: Ignition/Starter Switch  (Read 1574 times)
Offline viperjsy
« on: 14 June 2014, 11:37 »
hi just replaced the  Ignition/Starter Switch is this look right. here is  a pic of the old one
Offline Tezmax
Re: Ignition/Starter Switch
« Reply #1 on: 14 June 2014, 17:29 »
Compare it with this one i took out 2yrs ago :wink:
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline viperjsy
« Reply #2 on: 14 June 2014, 20:11 »
thank you
Offline old_n07
« Reply #3 on: 15 June 2014, 19:29 »
If the switch doesn't fix your starting problems (assuming that's why you swapped it  :undecided:) take a look at the starter motor and you will see a single wire that attaches to the rear, it is the wire that energises the coil.  The connector corrodes and this can cause poor starting issues, chop it off and replace  :wink:
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline viperjsy
« Reply #4 on: 18 June 2014, 23:45 »
it dose start all the time but I had a dtc code up
