Author Topic: Fan overrun  (Read 7668 times)
Offline p9ul
Fan overrun
« on: 14 June 2014, 10:07 »
A couple of times now, after only a short 3 mile journey from work to home, the fan has kicked in when switching the engine off, and only goes off when switching the ignition on and off again.
Anyone any ideas?
Offline SRGTD
Re: Fan overrun
« Reply #1 on: 14 June 2014, 11:11 »
It may be the DPF going through an active regeneration to burn off the soot deposits that have accumulated in the DPF. See reply #18 in the thread below.
http://www.golfgtiforum.co.uk/index.php?topic=259626.msg2387838#msg2387838
If you do mainly short journeys, it's advisable to give your car a good motorway blast regularly, to help keep the DPF clear of excessive soot build up.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline p9ul
Re: Fan overrun
« Reply #2 on: 14 June 2014, 19:03 »
Thanks for the info.
How long does this active regen cycle last if we let it run it's course?
Offline SRGTD
Re: Fan overrun
« Reply #3 on: 14 June 2014, 21:14 »
Not sure, as I can't remember when I last had an active regen with my mk6 and it may be different for the mk7.
Probably worth using the search function in the mk7 section of the forum and search on DPF as I think this has been discussed by other forum members.
Offline TheCarMadDad
Re: Fan overrun
« Reply #4 on: 14 June 2014, 22:33 »
This ^^^^
aka 'The Italian Tune Up'!
:D
2014 Mk7 Golf GTD 5dr | Tornado Red | Keyless Entry | Climate Comfort Screen > Which means I also have the ATP. Also fitted with DTUK Stage 2 box ...Loving every second behind the wheel!
Previous...
2008 Toyota Prius T Spirit (fastest 0-15mph car I have ever owned :p )
2005 Subaru Legacy 2.5 SW
2003 Lexus IS300
2002 Seat Leon Cupra R
Offline C2K
  • Northern Monkey
Re: Fan overrun
« Reply #5 on: 15 June 2014, 00:01 »
10 to 15 mins for an active regen. Fan wouldn't go off though with ignition as it's trying to cool the dpf.
5 Door Night Blue GTD
Dynaudio, 19" Santiago Alloys, Adaptive Chassis, Leather Pack, Winter Pack, Reverse Camera.
Bianca White 306 Rallye (Supercharged + Caged) : Melting Silver F54 Mini Clubman Cooper S
Offline barryg
Re: Fan overrun
« Reply #6 on: 16 June 2014, 13:38 »
on my previous car a Scirocco 140tdi the fan over run could be stopped by turning the engine on and off,my GTD over runs at times for about 15mins told by garage its a natural occurance to clear dpf on short runs seems to occur more often on this car than it did on the Scirocco.
Offline Rick101
Re: Fan overrun
« Reply #7 on: 18 June 2014, 09:20 »
I've had this and also had it on my old Octavia VRs, always thought it was a fault with the temp sensor sticking as it always seemed to happen in cold weather.
Fan is on full and remains on after switching off. If you switch on and off again the fan stops.
Should be something about it in the manual if its the case that is normal as I wasn't happy leaving the fan blaring at full speed in work car park and niot going back to if for 12 hours.
