Author Topic: lights  (Read 1077 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
lights
« on: 07 September 2005, 17:48 »
right got bit of problem my passenger side light went out other night on the rear
i changed bulb today and it still is not working and no fuses are blown and it seems ot be plugged in properly
any ideas what i can do
and also i thought i would fix my reverse lights as they did not work when i changed gearbox
because plugs were different so my friend checked them on sum gadget he had and they was power there
but when he hooked them up to the gearbox nothing happens lights ownt come on and bulbs are fine
help please just dont want to get pulled by cops
cheers
Rob118
Online Agreeable Slick
  • Unit
Re: lights
« Reply #1 on: 07 September 2005, 18:43 »
regarding the reverse lights, i am pretty sure the switch is a bit tempremental when you mess around with them, sometimes just don't engage for some reason. Rear light prob a dodgy solder on the board somewehre.
Judderi
Re: lights
« Reply #2 on: 08 September 2005, 09:14 »
Also for your rear lights try unplugging the wires from the board and back on a few times. This will clean the contacts a little and might do the trick.
Offline VR6_ROB
Re: lights
« Reply #3 on: 08 September 2005, 18:43 »
nice 1 cheers folks ill give it a go
Offline Mr Blue
Re: lights
« Reply #4 on: 08 September 2005, 19:19 »
i bashed mine yesterday and that done the job :smiley:
