Author Topic: Mk2 16v running issues  (Read 1621 times)
Offline nawaters
« on: 12 June 2014, 13:54 »
Hi all, basically it broke down on me, the AA man said it was the dizzy and ignition coil so I replace both with new bosch units, still no spark... Did some wiring tracing and found one wire that plugs to the dizzy hall sensor pick up had snapped inside the rubber cover. Was a little annoyed buying new parts for a duff wire but hey lesson learnt.
Anyway the engine is coming out for a freshen up gaskets and seals ect. I found another wire that has snapped and cant find which way round they plug in. Its a 3 pin connector under the throttle body for the micro switch all 3 have snapped from the connector and look like they have a long time ago.
Can someone please post a pic so i can see the order  :wink: its a 16v KR Cheers :cool:
Offline Sgt_Lemon
  • 8v owners club
Re: Mk2 16v running issues
« Reply #1 on: 12 June 2014, 19:53 »
If you have a Haynes manual a wiring diagram is at the back with colours and locations.
