Golf mk4
Wazzzer
MK4 Gti anni ! Brown sludge :(
Topic: MK4 Gti anni ! Brown sludge :( (Read 7244 times)
Jay25edition
12 June 2014, 06:54 »
Was happily driving to work this morning and all of a sudden had a warning on the dash saying STOP check coolant. So I pulled over checked the coolant to find it's full of like watery brown sludge?
The felt like it was running fine... Checked oil cap and seems to look normal?
HELPPPPPP
Silver polo gti 6n2, blackberry corrado 2.0, tornado red mk4 golf gti anniversary.
rio_gti
"i'm not spending any money on it" Got a Hybrid!
Re: MK4 Gti anni ! Brown sludge :(
12 June 2014, 08:43 »
Sounds like head gasket.....
Give the water system a flush and refill (not forgetting g30 I think) and check again...
Also check oil levels make sure it isn't going down
2000 GTI 1.8t ARZ, S2000 filter, DSG intake, Forge 007 dv, Catch can, R-tech custom remap, 3" Supersize Silicone TIP, Powerflex dog bone, 'The Beast' FMIC, Ultimate delete, LCR fuel pump, 3" Turbo back, K03 hybrid, Ported Manifold, S3 injectors, 80mm maf = 280bhp 270lbft
1.8Tgolf_Chris
Here all the time
Mk4 1.8t AUM
12 June 2014, 12:14 »
straight to the garage for u my friend for a large repair bill, or cut ur losses and break it for parts
Dalo Harkin
12 June 2014, 12:32 »
I would do as Rio suggested before looking to break it
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Jay25edition
12 June 2014, 17:57 »
Last Edit: 12 June 2014, 22:11 by Jay25edition
Wayne
Sir Postalot
13 June 2014, 00:07 »
I would not panic just yet it could be the oil cooler failed
Nino
Reply #6 on:
13 June 2014, 06:44 »
yep, its now a process of elimination, get the coolent fully flushed, check oil and go from there.
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door
WadGTI
Here all the time
Golf GTI'er
Reply #7 on:
13 June 2014, 12:23 »
If you can, get a compression test done.
1.8Tgolf_Chris
Here all the time
Mk4 1.8t AUM
Reply #8 on:
13 June 2014, 17:23 »
think my first option was abit severe, get a combustion leak tester that would tell if ur head gasket is gone first then as every1 else has suggested
ant_gti
GTI forum regular
mk3 20v turbo
Reply #9 on:
13 June 2014, 17:57 »
What Wayne said oil cooler
Golf mk4
Wazzzer
