Author Topic: List: What i need to mate a 8v box to a 16v engine.  (Read 1438 times)
Offline Agreeable Slick
  • Unit
« on: 07 September 2005, 16:56 »
Right i know i need the basics like,
Box,
Clutch,
Flywheel,
I have most of the above covered, but what do i need to complete it??
I.e. Driveshafts, draveshaft seals, flanges, boot kits, etc etc,
Need this in double quick time please chappies.
#cheers.
Offline Mr Blue
Re: List: What i need to mate a 8v box to a 16v engine.
« Reply #1 on: 07 September 2005, 17:01 »
isnt the flywheel the same? thought u had to mix and match the clutch only???  :rolleyes:
  • Unit
« Reply #2 on: 07 September 2005, 17:14 »
nope as far as i am aware, the fly is a different diameter to the 16v. I have a lightened one on the way.
Just need to know if i need to change driveshafts etc.
Offline Veedub1989
« Reply #3 on: 07 September 2005, 17:29 »
i did this to my 16v - till the box went bang (make sure the box is good!).....
im pretty sure the flywheels are the same, i never changed mine. the clutches are different and the pressure plates are the same. You can use the original driveshafts from your 8v although if you can get hold of the 16v items would be best to fit these.
VW Golf 1989 2.0L 16v
  • Unit
« Reply #4 on: 07 September 2005, 17:35 »
Mine is the 16v, and i am fitting a 8v box. So from everything i have heard all i need is the clutch and box, i am getting the fly regardless as it is lightened and a bargain. Cheers Stu.  :wink: :evil:
Judderi
« Reply #5 on: 08 September 2005, 09:11 »
Can i ask why you are putting an 8v gearbox on a 16v?
  • Unit
« Reply #6 on: 08 September 2005, 11:19 »
sprinting.  :smiley:
Offline Mr Blue
« Reply #7 on: 08 September 2005, 11:26 »
abit off topic here. Would a 4+E box be any good for sprinting or are they just stronger?
