Author Topic: Got some movement  (Read 1197 times)
Offline 1.8Tgolf_Chris
  • Mk4 1.8t AUM
Got some movement
« on: 12 June 2014, 01:38 »
Drivers side, if i grab the disc and rotate clockwise/ anticlockwise there is masses amount of play - The whole drive shaft moves with it as you rotate as far as it will go it makes a clonk before you rotate it back again
Would this be a new DS job? Wheel bearing?
Offline mcgee9t2
Re: Got some movement
« Reply #1 on: 12 June 2014, 12:49 »
think its normal to have a small amount of play.
my old car certainly did and it was fine for the whole time i owned that...
