Author Topic: Agu ko4 swap  (Read 3205 times)
Offline Jgomk4
Agu ko4 swap
« on: 11 June 2014, 18:40 »
Hi Iv just fitted a ko4 from a audi tt 225 but I need injectors to fit my agu inlet manifold. Which ones will fit??
Offline kier1990
Re: Agu ko4 swap
« Reply #1 on: 11 June 2014, 21:47 »
Ow mate ur in the same situation as me I'm doing a ko3 hydrid turbo conversion just so u know vr6 maf is perfect and I think saab redtop injectors are good depends on bhp I bought s3 injectors because got told they will fit but they don't
Offline davidgtrr34
Re: Agu ko4 swap
« Reply #2 on: 11 June 2014, 22:35 »
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Dalo Harkin
Re: Agu ko4 swap
« Reply #3 on: 12 June 2014, 12:40 »
I am using these and there working great. There able for 480bhp 100% duty cycle
http://www.ebay.co.uk/itm/Volkswagen-Jetta-Golf-GTI-1-8t-550cc-Injectors-550-cc-/160284586274?pt=Motors_Car_Truck_Parts_Accessories&hash=item2551b4b122
they look like the S3/TT ones, they are smaller, you need the larger ones like Calibra yellows or Saab reds
Offline kier1990
Re: Agu ko4 swap
« Reply #4 on: 12 June 2014, 13:15 »
Is it possible to get s3 injectors to fit agu inlet as already bought them if possible how much work ?
Offline Jgomk4
Re: Agu ko4 swap
« Reply #5 on: 12 June 2014, 14:07 »
Thanks for all your replies Iv gone for saab reds. The only other thing is my down pipe Iv got a 3in leon cupra mk1 down pipe as told by miltek that this will work. Hope it does it cost a nuff.
Offline Jgomk4
Re: Agu ko4 swap
« Reply #6 on: 15 June 2014, 19:00 »
Audi tt maf!! Do I use just the casing and use my sensor from my agu engine or the complete maf? Tanks guys
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Agu ko4 swap
« Reply #7 on: 15 June 2014, 19:40 »
You don't use an Audi TT MAF on an AGU, you use the Golf VR6 MAF and it's just the casing with your standard AGU sensor
Offline rio_gti
Re: Agu ko4 swap
« Reply #8 on: 15 June 2014, 20:08 »
I got a bora v5 maf to go on that's also 80mm  :wink:
Offline Jgomk4
Re: Agu ko4 swap
« Reply #9 on: 16 June 2014, 16:39 »
So I can't use the tt maf casing then?? As it came with turbo and that don't want to waste it. Mk1 lcr down pipe will it fit my mk4??thanks
