Author Topic: do Xenons need calibrating after replacing both bulbs?  (Read 1400 times)
Offline candywhite12
what the topic says.
i think they have a function for self-calibrating - moving right, up and down ... but on other forums people suggest this should be done by the dealer  :sick:
ta
Wife's: mk8 TSI 1.4 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Now: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Snoopy
  • Moderator
  • Geoff.
Re: do Xenons need calibrating after replacing both bulbs?
« Reply #1 on: 11 June 2014, 22:49 »
Thats just a function test to show they work.
they auto level compared to the car but if the beam pattern is set wrong to start with they will always be wrong.
Depends if you think they are out. In an ideal world everytime a bulb is changed the alighnment should be checked and re-ajusted.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
« Reply #2 on: 12 June 2014, 08:04 »
by out i take it you mean not properly aligned?  When i replaced the OEM xenons myself and switched on the car, the xenons moved up/down etc as always and then moved back to their 'aligned' position - there doesn't seem to be anything wrong with how they behave or with whether they beam compared to before.
