Author Topic: putting old clocks back  (Read 1460 times)
Offline Scottymk4
« on: 11 June 2014, 15:21 »
was wondering, got bora sport clocks fitted but they aint working right, can i just plug my onld clocks back in or do they need to be coded in ?
Offline Scott D
Re: putting old clocks back
« Reply #1 on: 12 June 2014, 00:41 »
they'll need to be coded back in to match the ECU to previous cluster IIRC
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 12 June 2014, 20:17 »
yep, keys will need to be matched back to the old cluster as they clear the old matchings out
Offline old_n07
« Reply #3 on: 13 June 2014, 19:39 »
Hmm, mine just worked when I fitted my old cluster today  :wink:
When you fit a new cluster you don't wipe the old clusters key matchings, all you do (immo 3) is to pull the immo data from the ecu to the new cluster then match your keys to the new cluster, so if you put your old cluster back in it already has the immo data and keys matched to it so they should work. The only time you could have issues would be if you went immo2 to immo3
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 13 June 2014, 21:12 »
That might be why it did it for me then Neil, changing from immo2 to immo3
Offline Scottymk4
« Reply #5 on: 14 June 2014, 09:18 »
Yeah immo2 to immo3 for me too
