Author Topic: Ventureshield / Armourfend  (Read 2651 times)
Offline Pigpen
« on: 11 June 2014, 08:35 »
Looking at a Pearlescent White Golf R in deepest Devon would people recommend or avoid such products to help reduce stonechips?  Fully aware that in time this can start to yellow especially on white but £300-£500 seems a worthy option?  Any advice and comments appreciated.
Offline Brenbo
Re: Ventureshield / Armourfend
« Reply #1 on: 12 June 2014, 18:21 »
I have Oryx White and I live in even deeper and dark cornwall.  The Pearlescent White 'Oryx White' from I can gather is Pure White with a Pearlescent lacquer on top. or at least this is what you get when you buy the spray paint for Oryx White.
I have found Oryx White can be touched up on stone chips fairly easily with good results if you use Chipex or a similar touch up paint solution.  The thing that marked Chipex out from normal touch up paint for me is the fact you have a blending solution which removes all excess paint blobs on top of the surface after you touch up a chip.  This means the touch up is miniscule and the paint is only in the chipped area level with the surface of the paint.  The only time you can see if a chip is touched up with Chipex is in very specific lighting conditions and viewing angles. About 90% of the time you do not see it, and when you do, you have look really hard for it.
I would advise getting a touch up paint solution or use smart repair rather than the shield system you are are looking at.  Enjoy the new car.
I would get Oryx White again without hesitation
Hope this helps.
Offline Pigpen
« Reply #2 on: 12 June 2014, 18:24 »
Topman Brenbo!  Hope to bump into you at some time then but not literally!  How far down are you my work brings me down through Cornwall and I am based at Holsworthy.
Offline Brenbo
« Reply #3 on: 12 June 2014, 20:24 »
I am situated around the Launceston area, surf in Bude. Great times living in the south west.  I currently own a GTI Performance which at present is the perfect car for me. Was thinking about a Golf R, always think I will be tempted.  Maybe one day I will take a punt and go for it.  Maybe we will cross paths one day.  Getting bored only seeing GTD's other than my GTI in the local area  :smiley:
Offline Pigpen
« Reply #4 on: 12 June 2014, 22:02 »
Roads are definitely a lot worse up here than Launceston  :grin:
Won't get mine until September though  :angry:
I'll keep an eye out for you as you aren't much more than 10 miles away!
