Author Topic: strange rubbing/grinding noise coming from front wheels.  (Read 3211 times)
Offline Rob.S VW
  • Fatlace since 1999
hi, i have a strange noise coming form the front of the car around the wheel area, orginally thought it was the brakes grinding from weae, so changed the discs and pads, the noise still continues, my golf is lowered so checked it wasnt rubbing on the ARB, still loads of room between the drive shaft and ARB, ive changed the ARB bushes as they need replacing, the noise goes with the speed of the car, my mate Wazzer check it over with me too, its not wheel bearings. its doing my head in, ive also checked the splash guards there fine, anyone have any ideas, cheers.
2002 25th Anniversary 1.8T-224hp-262ftlb-Stage1 Revo map-Forge 008p-Forge Turbo inlet pipe-Pipercross Panel Filter-DSG Intake-Milltek downpipe & sports Cat & Catback-Newsouth Boost Guage.
Offline EsSeX dAn
Re: strange rubbing/grinding noise coming from front wheels.
« Reply #1 on: 10 June 2014, 22:32 »
could be your inner cv's stsrting to wear or maybe even a bent alloy! i had it on a fiesta once, for ages i had this wheel besring sound. i changed all the bearings and everything else but was only cured when the wherls where changed
i think i love you.....
Offline MoMartin
« Reply #2 on: 10 June 2014, 23:02 »
Is it on coilovers? because mine is and depending how low i have it, i suffer from the adjustable cog rubbing against my wheel.
have a look at the inner side of the wheel to see if there are any marks on it too, that might help you find the cause.
Offline Tezmax
« Reply #3 on: 12 June 2014, 17:54 »
And back to the to coz i have same issue, changed front pads n discs still got rubbing/grinding sound?
Its not bearing on mine either.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 12 June 2014, 20:22 »
He's running 15mm spacers on the front so it's not catching the strut...
Rob bring her round again and we'll have a look
Offline MoMartin
« Reply #5 on: 12 June 2014, 21:05 »
Sounds like the brakes are binding a bit? Did you reverse the brake piston back in when you did it? Because that might cause the brakes to bind, if it is the brakes making the sound.
Offline Tezmax
« Reply #6 on: 14 June 2014, 10:26 »
Defo not the brakes coz i had the same rubbing noise before and after replacing the disc's and pads.
Gona jack the whole front end up today and have another poke around.
Offline Rob.S VW
« Reply #7 on: 14 June 2014, 17:33 »
Thanks for the replies, it's not the brakes I don't think, I've changed the discs and pads still makes the noise. Was making the same noise with the old discs on, unless the brakes were binding then as well. It's only accrrured since I've lowered it. Had it in the garage today and the mechanics couldn't figure it out.
Offline Tezmax
« Reply #8 on: 19 June 2014, 19:41 »
Lol, mehanics had a look today and couldn't figure mine out either :laugh:
They have suggested changing lower suspension arm and top strut bush and go from there.
In their own words "we can't identify exactly where to noise is coming from"  :huh:
