Golf mk4
Wazzzer
Oil filter housing loose
Topic: Oil filter housing loose (Read 1144 times)
Tezmax
GTI forum regular
09 June 2014, 20:04 »
Changed my oil and filter today but when twisting the filter off I found the housing turning with the filter
I have tightened up the visible 25mm nut and put the new filter on.
Do I take it this will be fine and dont need to worry about it?
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
northeast_gti-t
Serious forum addict
"1.8T AGU"
Re: Oil filter housing loose
10 June 2014, 22:20 »
as long as the nut has tightened onto the o'ring seal enough that should be fine if there is oil leakage evident then you haven't cured it
2000 Mkiv GTi 1.8T AGU
Golf mk4
Wazzzer
