Author Topic: knocking wishbone bolt-oval subframe!  (Read 1619 times)
Offline paultownsend
« on: 08 June 2014, 20:14 »
so i have had a knocking for a while. turns out its the wishbone bolt that goes through the rear bush/subframe.
i picked up, and torqued up new bolts from VW. still knocking. took them off for another look and the subframe hole looks ever so slightly ovaled. what options do i have?
new bolt obviously, but would i be better using a high tensile steel bolt and put some mega torque on it?
i tried torqing up the old vw bolt (stretch bolt) but it just went soft.
could i try fit a new bolt then spot weld to subframe?
Offline Jarrold06
Re: knocking wishbone bolt-oval subframe!
« Reply #1 on: 08 June 2014, 22:08 »
This happened to me I got a new wishbone stopped took it off again as was trying it to see if it would stop to then put my new bolts in and it was sound till my mate cross freded the bolt for anti roll bar link so had to get a new wishbone
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 09 June 2014, 09:30 »
The subframe does have a slight bit of movement via the holes anyway.
It will need tracking again once you have taken it off
« Reply #3 on: 09 June 2014, 12:49 »
@ wazzer, do you mean the holes the the subframe where the wishbone bolts go through?
I have just had another look and compareed both sides. I do not feel this is the problem. But it still knocking. and you can feel something knocking. the bush is a brand new lemforder r32 item.
« Reply #4 on: 09 June 2014, 20:24 »
i fixed it! i fitted poly ARB drop link bushes a while a go and basically they are crap. also the bolts were seized, and i may have done them up too tight! all greased up and all new stretch bolts. again! back to the OE drop links me thinks!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 09 June 2014, 20:44 »
ha good stuff mate
