Author Topic: Dash bulb problem  (Read 1889 times)
Offline matty1664
Dash bulb problem
« on: 06 June 2014, 16:18 »
Hi I'm after a bit of help please.
I'm trying to change my dash bulbs but I can't get the new ones to work. I've taken the dash fascia apart and taken my clocks out, changed for new bulbs (12v so should be the same) but when I try and turn them on again they still aren't working.
What else can I check to see if the problem is elsewhere? I have tried turning the bulbs around into different positions as well.
Matt
Offline Sgt_Lemon
  • 8v owners club
Re: Dash bulb problem
« Reply #1 on: 07 June 2014, 18:55 »
I would live test the light terminal
Offline matty1664
« Reply #2 on: 08 June 2014, 12:37 »
cool, do you think a new set of clocks will solve the issue?  I have checked fuses and they are all ok. Now bidding on new set of clocks.  After that I have no idea.  Electrics are way out of my league, I'm a complete beginner!   :embarrassed:
Offline oakgreener
« Reply #3 on: 08 June 2014, 16:47 »
Could be the clocks circuit board or the lighting switch or possibly the wiring between. You need to get yourself a cheap multimeter and set it to 20volts DC and check the wiring at the switch. Check to earth ( body metal work).
Good luck :smiley:
Offline Brighouse-gti
« Reply #4 on: 08 June 2014, 21:21 »
Which 'bulbs' are you tryin to change?.. The bulbs that illuminate the speedo are on the rear of the speedo box, you don't need to dismantle the box to get to these they just twist lock into position, if its the led's on the front of the speedo box which are your warning lights indicators oil ect, then replacing them is a bit of a mare so you probably would be better gettin one of the olde eBay, just make sure part number is right first!!
