Author Topic: Parking sensors  (Read 9251 times)
Offline C3PO
Parking sensors
« on: 05 June 2014, 18:13 »
Reversed off the drive this morning and halfway off instead of the beeping, I now get a high pitched noise and the button near the gearstick flashes, think I have a fault. Anyone experienced this before?
Mk6 GTI, 18" monza shadows, Leather, Bluetooth Phone - gone
Mark 7 R, 19" wheels, lapiz blue, 5 door, leather, reversing camera - gone
2018 Audi S5 Sportback, pano roof, LED Headlights  B&O sound system - gone
Current 2020 Golf GTI TCR, pure grey, pano roof , 90% tints and Akrapovic exhaust.
Offline Rhyso
Re: Parking sensors
« Reply #1 on: 05 June 2014, 20:57 »
Sensor has failed
A scan with VCDS or dealer tool should identify which one is playing up  :smiley:
Offline Snooze
Re: Parking sensors
« Reply #2 on: 06 June 2014, 21:08 »
Same thing happened to mine. Stealers couldn't tell me if it was a sensor or control unit fault. Wanted another £200 odd to investigate further. I told them to jog on. Just living without them ATM!
2015 Mk7 Golf Gti 3dr Manual, Carbon Steel Grey, Michelin PS4's
Offline Rhyso
Re: Parking sensors
« Reply #3 on: 06 June 2014, 21:17 »
If you have VCDS you could remove the bumper and move the sensors about
If the fault moves then you know its a sensor  :smiley:
Offline C3PO
Re: Parking sensors
« Reply #4 on: 07 June 2014, 19:52 »
Cheers chaps, have contacted a local independent who can diagnose for around 30 quid, then will decide what to do next. Anyone know how much a new sensor is bearing in mind they are colour coded?
Offline ajmoir36
Re: Parking sensors
« Reply #5 on: 08 June 2014, 09:24 »
My dads mk4 Bora did this, if you place your ear over the sensors you can hear them clicking (i.e. ear touching the sensor with the sensor in you ear hole), obviously ignition on in reverse. I scanned with VCDS and it never shown a fault. Using this method we identified one that didn't click, bought a new sensor somewhere in the region of £90 replaced it and fault went away (they were black luckily).
« Last Edit: 08 June 2014, 09:26 by ajmoir36 »
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline C3PO
Re: Parking sensors
« Reply #6 on: 28 June 2014, 09:54 »
update - so had indie tech in MK look into the fault this morning, and its not a sensor that has failed :shocked:. It turns out that the fault code is described as "front parking aid warning chime H22". He advised that the part is only £13 which sounds great, however, he has no idea where it is located in the car (could be in the roof or behind the dashboard). any advice welcome :smiley:.
Wife's advice was why bother of course, but I like everything to work as it should.
Finally, whilst in he said the battery was almost flat, which I find strange as I had not noticed any issues, anyone experience anything similar?
Thanks
Offline Mattyj
Re: Parking sensors
« Reply #7 on: 28 June 2014, 22:25 »
Thanks
No doubt someone with etka will help you out with its location
Offline Keithuk
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline C3PO
Re: Parking sensors
« Reply #9 on: 29 June 2014, 19:36 »
Have you Googled Golf Front Parking Aid Warning Chime (H22) location?
Removing and installing front parking aid warning buzzer -H22-
Adjusting volume of front parking aid warning buzzer -H22-
Workshop Manual Golf, Jetta 2007>
Believe it or not, no I didn't think to google it :lipsrsealed:
Thanks so much, looks really easy.
Will update once done.
