Author Topic: Fob issues!! SOLVED!!!  (Read 1773 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« on: 04 June 2014, 14:20 »
Got a slight problem!
Changed the battery in my key and now it won't unlock my car?
Havent got any key locks on the doors so can't get in and havent got a spare?!
Batteries are brand new.
Is there a time limit on changing the batteries over? Is there anything I can do other than call the recovery van to take me to a vw dealer?
« Last Edit: 05 June 2014, 15:21 by Perryd84 »
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline itavaltalainen
Re: Fob issues!!
« Reply #1 on: 04 June 2014, 17:18 »
Just re-match them....
http://www.youtube.com/watch?v=eQVRVcTZzus
You don't have any locks on your car though?? Not even in the boot??
Phone the AA to open the car for you rather than have it towed.
Offline Perryd84
Re: Fob issues!!
« Reply #2 on: 04 June 2014, 17:24 »
Got a key on the boot but the alarm goes off when I open it without opening the central locking?!
Offline Perryd84
Re: Fob issues!!
« Reply #3 on: 04 June 2014, 20:05 »
Seriously guys need help here!?
I can open the boot but the alarm goes off. Climbing through the car to open the doors doesn't work the central lock buttons on the driver door do nothing and manually pulling the door handle does nothing it just re locks itself.
HELP!!!
Offline topher
  • Administrator
  • fully functioning
Re: Fob issues!!
« Reply #4 on: 04 June 2014, 21:24 »
your doors are safelocked so you cant open them from the inside. when you crawled through the boot did you turn the ignition on before trying the doors? that will usually disable the alarm and undo the safelocks.
Offline Perryd84
Re: Fob issues!!
« Reply #5 on: 04 June 2014, 21:53 »
Didn't try that. I'll give that a go tomorrow and see how I get on.
Offline Perryd84
Re: Fob issues!! SOLVED!!!
« Reply #6 on: 05 June 2014, 15:23 »
Worked a treat Topher :grin:
Started car and alarm turned off and doors unlocked and then recoded the key with Vagcom :grin: :grin:
Thanks a lot for the help!!
