« on: 03 June 2014, 21:25 »
Need to raise the front coilovers as its down way too much and causing issues when turning with tyre catching on arches - looks awesome but totally impractical scraping.
Never had coilovers before but guessing they are adjusted loosing grub screw then turning clockwise up towards the top of strut.
They are AP's that are fitted
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
