Author Topic: Any issues after 45D4 update?  (Read 7342 times)
Offline adekil
« on: 03 June 2014, 16:07 »
Car was in garage last week and they had a recall too for the 45D4 bug fix and since getting the car back I get random issues where my SD card is not automatically detected upon engine start, pressing media button then switches to the SD fine, stop and start the engine and its fine again for a while. Also the park assist alarm comes on at times when navigating the menus, again this is random and I have to disable the park assist for it to stop, car is not close to any object either.
Anyone else have this update and noticed anything unusual afterwards?
Current(2024): MK8 Golf R, Pure White, RV Camera & 19" Estoril Diamond Cut
Offline mcmaddy
Re: Any issues after 45D4 update?
« Reply #1 on: 03 June 2014, 17:45 »
The SD card auto detect glitch was present pre update (this isn't a recall) so I don't think it's been caused by it.
Offline adekil
« Reply #2 on: 03 June 2014, 17:56 »
Ah OK didn't know that McDaddy, never had the SD detect issue before, just coincidence then but on the same day the parking assist alarm comes on when browsing the car menus  :undecided:
Offline mcmaddy
« Reply #3 on: 03 June 2014, 18:02 »
I get the false parking sensor sound too but things like leaves or bits of paper or even worse massive bees set it off.
Offline 205Rallee
« Reply #4 on: 05 June 2014, 18:51 »
Didn't know anything about this until my GTD went for the first service, what does the update do? The garage just said it was something to do with the engine ECU, but couldn't tell me anything else....
Offline andrewparker
« Reply #5 on: 05 June 2014, 19:16 »
When was this update issued?
Current – Mk7 Golf R, Night Blue, 5dr, Manual / Mk7.5 Golf R, Indium Grey, Estate, DSG
Offline Darlo
« Reply #6 on: 05 June 2014, 19:19 »
Had this done today. No issues as yet
Offline mcmaddy
« Reply #7 on: 05 June 2014, 21:18 »
It's for the abs ECU apparently amongst other things.
Offline adekil
« Reply #8 on: 07 June 2014, 19:10 »
Since I started this post I've had no repeat issues and so seems to be pure coincidence what I experienced, probably a bit too hasty posting TBH. My driving experience otherwise hasn't changed since the update such as my only issue with the throttle response in Sport mode from engine start
Offline chris283
« Reply #9 on: 26 June 2014, 22:02 »
Mine has been in today only to find two hours later that the window opened an inch (when engine was started) and will not shut or open. Also drivers door will not lock, nsr window in op,  electric mirror with repeater not working. Non of the 4 window switches work but the o/s windows both work ???
Could just be an ironic coincidence
