Author Topic: oil leak from filter sandwich plate?  (Read 1617 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 31 May 2014, 23:48 »
Anyone had this? If so what parts are needed and how easy was it to do?
Noticed a dribble from mine today and tracked it to behind the oil filter sandwich plate so I'm guessing the gasket behind it has gone. It's due a service in the next week or so so it's an ideal opportunity to get it done
Offline boneybradley
  • Back in a Mk3...
Re: oil leak from filter sandwich plate?
« Reply #1 on: 01 June 2014, 14:05 »
this is the gasket between housing and head which are £12
then there is a seal between housing and the oil cooler which commonly split! these are £4
Offline james2
  • No scammers please.
« Reply #2 on: 01 June 2014, 14:20 »
I changed my oil cooler for a new one off ebay ,it had a rubber O ring on top. There is a nut you need to remove after you remove the oil filter. Remove the oil cooler and replace the O ring.  :nerd:
http://www.ebay.co.uk/itm/Febi-Bilstein-Seal-oil-cooler-Volkswagen-GOLF-Mk-IV-1-8-T-1997-2005-/161322195105?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVW%7CPlat_Gen%3AMK+IV&hash=item258f8d58a1
« Last Edit: 01 June 2014, 14:33 by james2 »
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 01 June 2014, 16:28 »
yeah it's the O ring Boney, not the actual housing gasket
I've found the O ring on ETKA so I'll see what the damage will be from VW tomorrow
thanks for the replies
