Author Topic: Tyre rotation  (Read 3638 times)
Offline Booth11
Tyre rotation
« on: 31 May 2014, 20:34 »
Hi all
It's time to replace my original rear tyres which are currently on the front.  I'm sticking with Conti SC 5p's which I rate highly.
Now I know opinion is divided on whether new tyres should go on front or rear, and I fall into the latter camp.  However it's only 4 months since I replaced the worn out fronts and had them rotated to the rear.  So the rears have got just over 3,600 miles on them.  Is it worth rotating again and putting the new ones on the rear or just stick 'em on the front?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline golfhappy
Re: Tyre rotation
« Reply #1 on: 31 May 2014, 20:39 »
I'd go for the new on the front.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline Mattyj
Re: Tyre rotation
« Reply #2 on: 31 May 2014, 20:49 »
I'm with new on front but defo rotate did mine today the vredsteins on the bk are still like new nearly 8 months old the front falkens are a few mm off the wear indicator
Offline ajmoir36
Re: Tyre rotation
« Reply #3 on: 31 May 2014, 22:25 »
I go with new on the front on a front wheel drive. Don't like under Streer.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline itavaltalainen
Re: Tyre rotation
« Reply #4 on: 31 May 2014, 23:29 »
Rear tyres are what gives your car stability, hence new to the rear ALWAYS. Even if it's a FWD.
In case of Booth11 - if they've only ran 3.5k miles on the front then you're OK to keep them there and put the new ones on the back... Unless you drive like a maniac you wouldn't have worn them a lot.
Offline Booth11
Re: Tyre rotation
« Reply #5 on: 31 May 2014, 23:42 »
Agree with the above about new tyres being better on rear and that is my usual practice.  But in this case the tyres with only 3.5k are on the rear NOT the front.  They've been on rear since new, 4 months ago, so they shouldn't be worn much.  When I replace the fronts in couple weeks (which have 17k on) I'm not sure it's worth putting them on the rear as the current rears are relatively new.  Sorry if that wasn't clear in my original post.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Mattyj
Re: Tyre rotation
« Reply #6 on: 31 May 2014, 23:49 »
As i've said before i NEVER put new on the rear how often do you drive like a clown to invoke understeer? Majority braking: front power: front steering: front weight: front thats me tho
Offline Booth11
Re: Tyre rotation
« Reply #7 on: 31 May 2014, 23:59 »
I don't agree Matty, I'm with itavaltalainen on this.  As I said, opinion is divided on this issue and has been argued many times over and no doubt will be again and again.  :rolleyes:
I guess in my case it probably won't make much difference either way. I'll probably end up switching new to rear as usual, even if the existing rears don't have many miles on them.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Mattyj
Re: Tyre rotation
« Reply #8 on: 01 June 2014, 00:58 »
We don't have to agree budd as we've said before everyones entitled to an opinion if we all thought the same it'd be a boring world.
Re: Tyre rotation
« Reply #9 on: 01 June 2014, 07:04 »
I'm another "new on the rear" voter but with only 3k on the rears it would be pointless swapping them to the front Madame Booth no matter how bad your car OCD is!  :grin:
So yes, go with your original thoughts and those of italvaltainan.
