Author Topic: Strange knocking on the boot / the rear of the car  (Read 1837 times)
Offline MoMartin
Hi, recently my car has developed an annoying knocking noise at the rear of the car (could be inside or out - sounds a bit like it's outside though). This seems to have developed since my rear left rubber mount for the spring broke (wore right down, so it was patchy) I have since then replaced this rubber mount, but there is still an annoying noise, it happens more often when I go over slightly bumps rather than larger bumps such as speed bumps.
Has anyone got any ideas on what it might be?
Cheers, Mo
Offline james2
  • No scammers please.
Re: Strange knocking on the boot / the rear of the car
« Reply #1 on: 31 May 2014, 19:48 »
Rear bushes need changing.  :nerd:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Bandit127
« Reply #2 on: 31 May 2014, 19:58 »
[/quote}
Unless your spare wheel, tool kit etc is slopping around unsecured then this ^^^
Offline MoMartin
« Reply #3 on: 31 May 2014, 20:57 »
Are there any other things it might be? Because I really cba with another big'ish job to do  :angry:
Offline dom
  • Back in a Mk4
« Reply #4 on: 31 May 2014, 21:36 »
There's a chance that it could be the top mounts but I doubt it. Rear axle bushes are the most likely culprit.
Offline Dalo Harkin
« Reply #5 on: 03 June 2014, 13:33 »
Is there anyone in the boot  :grin:
Offline MoMartin
« Reply #6 on: 03 June 2014, 14:01 »
I suppose that would explain the occasional scream in the boot too, though, the sounds have gone a bit dead lately, so who knows...
Offline Bandit127
« Reply #7 on: 03 June 2014, 17:39 »
Maybe your rear brake caliper was loose... LOL.
Offline MoMartin
« Reply #8 on: 03 June 2014, 18:11 »
Strangely, I haven't heard the same noise since it was temp fixed  :grin: so for all I know it could be that haha, though would that explain why it knocked on a little bump?
