Author Topic: Xenon Flicker  (Read 4834 times)
Offline GS WAX
Xenon Flicker
« on: 30 May 2014, 07:51 »
Advice needed please,
 obviously at night, when driving over rough bumpy roads the lights beam pattern flickers on more severe bumps and jolts!!! Best I can describe it is like a wobble of the bulb unit after a bump has impacted the car,seems more pronounced on the drivers side light beam pattern.
 I contacted the dealer and they told me it was the levelling system activating and perfectly normal.
 I'm not convinced,its almost as if the bulb is loose(but its not),its starting to get quite irritating now.
Anyone else noticed this before I book in with dealer to check it out.
2017 Clubsport Edition 40 #302
Offline golfhappy
Re: Xenon Flicker
« Reply #1 on: 30 May 2014, 10:40 »
I've got the retrofitted AFS system to my GTD and it doesn't do this! You cant really notice anything bar the turning corners and the lights follow, but no wobble.
Audi S1 gone, awaiting 1.5tsi r-line, pan roof, led lights front and rear, active dash, 18" jurva alloys and a dealer fitted Oettinger roof spoiler in tornado red.
Offline Mr_F
Re: Xenon Flicker
« Reply #2 on: 30 May 2014, 11:20 »
The levelling and turn of the lights is too slow to keep up on a country roads, I doubt it would be this.
61 Plate GTD 5dr, Shadow Blue, 18" Charleston's, Flat Tyre Indicator, Cruise Control, Bi-xenon (With Dynamic Curve), Storage Pack, Winter Pack and RCD 510.
Offline Booth11
Re: Xenon Flicker
« Reply #3 on: 30 May 2014, 13:04 »
No, no wobbling with my xenons, only notice movement at corners as said.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline candywhite12
Re: Xenon Flicker
« Reply #4 on: 30 May 2014, 13:16 »
hi mate.  my driver side xenon flickers as well but on top of that the color has changed to a more pinkish one.  do you have alteration in color?
Wife's: mk8 TSI 1.4 RL, 5dr atlantic blue, DSG, Norfolk 17", pan s/r, leds
Now: mk7.5 TSI 1.4 RL, 5dr tornado red, DSG, Singapore 17", pan s/r, leds
Before: mk6 GTI 5dr candy white, DSG, Monza Shadow 18", s/r, bi-Xenons, DCC
Even before that: mk5 GT 5dr tornado red, manual, s/r
Offline Mattyj
Re: Xenon Flicker
« Reply #5 on: 30 May 2014, 16:29 »
M8 had this on his beemer take the bulb out and have a good look at the base where the filament goes into the base his had a crimp to hold it in tight that fell out mite be worth a look
Offline GS WAX
Re: Xenon Flicker
« Reply #6 on: 30 May 2014, 18:38 »
Thanks Guys and B11
Spoke to dealer earlier :rolleyes:
Their Reply was Obviously no way to test this now because its Daylight Hours,my reply was "well just fit me a pair of new lights because when I first reported this it was winter and dark at  4pm ish and you fobbed me off :angry:
No change in color from when I purchased the car ,doesn't flicker on the wall in dark garage if I tap the light either,not wanting to smack it too hard tho incase I break it :smiley:
Its not a levelling thing I don't rekon,because it flickers a lot faster than the level check dance the lights perform when you turn them on,so something must be loose perhaps.
Offline itavaltalainen
Re: Xenon Flicker
« Reply #7 on: 30 May 2014, 19:39 »
agree something is wrong with your xenon bulbs... leveling is pretty smooth, unless you really hit a deep pothole VERY hard.
Offline Mattyj
Re: Xenon Flicker
« Reply #8 on: 31 May 2014, 06:56 »
Thanks Guys and B11
Have you checked the bulb? Screams same prob as my mates to me
Offline GS WAX
Re: Xenon Flicker
« Reply #9 on: 31 May 2014, 12:56 »
Had a good look around this morning,what a B***h to get too,
 it is the whole projector assembly that is wobbling, booked into VW on Thursday.
in the meantime is it safe to wedge a piece of foam or something inside the casing against the ignitor (or whatever the little silver box is on the back of bulb and obviously non flammable foam )or will it still get too hot and melt the foam?
