Golf mk7
Jimble
cooling fan!
Topic: cooling fan! (Read 2171 times)
vwjack
cooling fan!
29 May 2014, 22:05 »
is it normal to drive the car 2 miles tops and the cooling fan is on. AC is on.
itavaltalainen
VCDS and VCP - fault codes, coding, VIM activation
Re: cooling fan!
29 May 2014, 22:09 »
depends.... AC can trigger cooling fan to run, engine could be in active regen (if it's a tractor), sure there is a number of other perfectly normal things that can cause fan to come on
vwjack
Re: cooling fan!
29 May 2014, 22:12 »
yeah its a diesel. i dont even think the engine gets warm.
Jimble
Moderator
Forum addict
Re: cooling fan!
29 May 2014, 23:25 »
Quote from: vwjack on 29 May 2014, 22:12
It'll be doing a regen mate, if you do a lot of short journey's you'll notice it does that a lot, you need to stretch it legs now and again otherwise you might end up with DPF issues in the future.
mcmaddy
Forum addict
Re: cooling fan!
30 May 2014, 07:23 »
I drive my gtd 3 miles to work and back again on a night and don't get any extra regens. It does go further afield for other non work journeys so as long as it gets a good run out you won't have any issues with dpf's unlike previous diesels.
vwjack
Re: cooling fan!
30 May 2014, 13:36 »
Cheers fella's! I'd normally worry when the old jetta did it.
Golf mk7
Jimble
cooling fan!
