Golf mk4
Wazzzer
boot handle needing sprayed
Topic: boot handle needing sprayed (Read 1377 times)
Scottymk4
Here all the time
29 May 2014, 16:13 »
hey guys, the inside of my boot handle is looking a bit bubbly, has anyone sprayed this while still on the car?
MarcIV
GTI forum regular
Mk4 GTI
Re: boot handle needing sprayed
29 May 2014, 21:11 »
I'm doing the outside of mine, remove it rub it down spray it leave in and fix it back in! Good job! :p
If your careful enough I don't see why not, what's worst that can happen? Having to remove it and fix it that way? Have a go pal.
Flash Red Mk4 golf 1.8t GTI
Scottymk4
Here all the time
29 May 2014, 21:42 »
Yeah might just take it out and do it right
Dalo Harkin
30 May 2014, 13:10 »
only takes 2 mins to take the handle off
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Golf mk4
Wazzzer
