Author Topic: Turning driving lights of  (Read 1742 times)
Offline charlie
« on: 29 May 2014, 11:44 »
Probably been done before mine is a 62 plate car so I don't know if it is different to earlier gti's.  I have done the thing with indicator stick moved to the left position and no luck any suggestions would be a great help don't have xenons justly horrible yellow efforts  :whistle:
2012 black pearl Golf gti mark 6 5 door leather cruise 510rns bluetooth acc dab sunroof park assist rear camera parking sensors storage pack and the luxury pack :-) sold :/( now aiming a 2013 passat alltrack
Offline Booth11
Re: Turning driving lights of
« Reply #1 on: 29 May 2014, 14:15 »
Not sure if it's the same with non xenons but on a 62 plate with xenons the daytime running lights can't be switched off via the indicator stalk method charlie.  They changed it at some point, not sure when.  It tells you in the manual they can't be switched off.  May be able to do it using vagcom.
« Last Edit: 29 May 2014, 14:17 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline charlie
« Reply #2 on: 29 May 2014, 16:30 »
Thanks for the response booth checked destructions it says they can't be turned of manually :sad:
Offline itavaltalainen
« Reply #3 on: 29 May 2014, 17:00 »
can most likely be disabled with vcds :)
where are you based?
Offline charlie
« Reply #4 on: 29 May 2014, 17:42 »
I'm in Northants itavaltalainen :smiley:
« Reply #5 on: 29 May 2014, 23:27 »
nowhere near me, have a look on the vcds user map, should be plenty in your area
Offline charlie
« Reply #6 on: 30 May 2014, 09:38 »
Ok will do cheers
Offline RedHP
« Reply #7 on: 30 May 2014, 22:45 »
Hey Charles, me in Northants too pal
From what I know, only cars up to 10/11 plate have the option to turn off DRL's off through the MDF.
You may be able to do via VAGcom however. I have VCDS if you are really set on this, but again I don't know for certain that you can on the later model
Red
Mk6 GiT since birth in 2010
YNWA
