Author Topic: Is it just me?  (Read 1300 times)
Offline MarcIV
  • Mk4 GTI
Is it just me?
« on: 27 May 2014, 23:54 »
Okay I love my mkIV currently standard under the bonnet apart form a few forge pipes but sometimes when my foot is to the floor it seems to almost feel like it's lagging.
It doesn't always do this most of the time it pulls well but every so often it has a moment of a flat spot.
I've currently got a tiny hole at the tip end of my back box (new miltek is on my list) do we reckon this is causing the problem or is it something little more serious like turbo or boost pipes or anything ?
Or am I just a complete noob ?? :D
Flash Red Mk4 golf 1.8t GTI :)
Offline Scott D
Re: Is it just me?
« Reply #1 on: 28 May 2014, 01:03 »
find a local garage that can do boost leak testing and buy a cheap code reader from ebay - VW should of included one of these from new with the car  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline MarcIV
  • Mk4 GTI
Re: Is it just me?
« Reply #2 on: 28 May 2014, 19:18 »
Aha well my car is a little bit older now from new ;)
Offline Bandit127
Re: Is it just me?
« Reply #3 on: 28 May 2014, 19:39 »
I had this on mine. A throttle body clean and a set of new plugs sorted it.
To keep it tip top, it must get a good ragging now and then to blow all the crap out of the intake/turbo system.
It's not a V6 or V8, but the 1.8T does sound pretty good on the way past 6k revs.
Offline Rhyso
Re: Is it just me?
« Reply #4 on: 28 May 2014, 21:24 »
Could be any of the following
Faulty DV
Leaking pipework
Faulty N75 valve
Weak plugs / coilpacks
Faulty MAF
Or its just a complete pile of poo  :whistle:
