Author Topic: A bit of pulling  (Read 1495 times)
Offline Jarrold06
A bit of pulling
« on: 27 May 2014, 22:41 »
Ok so I got a question my car pulls slightly to the left when accelerating let go pulls back to the right not much only about an inch can only feel this when it's in 3rd 4th and 5th can't feel it when changing gear just on the straight now I know I have one cv boot ripped not sure if that will make it pull but since I found the rip in it that's when I started feeling the pulling can anyone give me any suggestions or advice thanks
Offline davidgtrr34
Re: A bit of pulling
« Reply #1 on: 27 May 2014, 22:44 »
Cv should have nothing to do with it. Check the wishbone bushings.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Jarrold06
« Reply #2 on: 27 May 2014, 22:46 »
Just changed the drivers side as they were f**ked the passenger side one were sound well mot bloke said that anyway
Offline MarcIV
  • Mk4 GTI
« Reply #3 on: 27 May 2014, 23:56 »
I would have changed both at same time :o
Flash Red Mk4 golf 1.8t GTI :)
Offline Jarrold06
« Reply #4 on: 28 May 2014, 00:25 »
Yeah I will be changing the other one soon just as the mot said that side and need my cat on and got a few other bits just didn't have enough money to get the other side but I will be changing it soon
Offline Scott D
« Reply #5 on: 28 May 2014, 00:54 »
You had wheel alignment checked recently?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Jarrold06
« Reply #6 on: 28 May 2014, 09:13 »
Yeah all that is sound to mate
Offline Jarrold06
« Reply #7 on: 31 May 2014, 21:11 »
Strangely enough i changed the cv boot today took her out on motorway and there was no pulling to the side when acceleration so god knows what it was i wouldn't of thought it could of been cv boot that done that
