Author Topic: Spark plug code help!  (Read 2578 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 27 May 2014, 22:26 »
Trying to remember the best plugs for a 1.8 Turbo, not been mapped so a standard 150BHP. I am sure the plugs recommended on here for the 1.8 20vt's are NGK.....Code is something like BGR6KE?  I have Bosch Super 4's in her at the mo' but read they are not meant to be any good for these engines?  Any thoughts and help with the code?
Thanks  :smiley:
Offline davidgtrr34
Re: Spark plug code help!
« Reply #1 on: 27 May 2014, 22:46 »
Super 4s are very bad my car misfired the second I put them in.
2004 auq, 550cc injectors, gt3071r, adjustable fpr, ebc, fmic, sachs stage 2, walbro 255, 3" turbo back, 3" custom intake, n75 n249 sai delete.
http://s103.photobucket.com/user/davidgtrr34/media/Mobile%20Uploads/20140531_192129_zpsgud6vsfb.jpg.html
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 27 May 2014, 23:02 »
What plugs do you have now mate?
Offline Scott D
« Reply #3 on: 28 May 2014, 00:57 »
I use NGK PFR6Q's which have been spot on in my mapped 1.8T
Not sure what the equivalent is for standard
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline brewey
« Reply #4 on: 28 May 2014, 10:18 »
I've got super4's it ATM and mines running fine.
2000 1.8T ARZ - OEM+
Offline Scottymk4
« Reply #5 on: 28 May 2014, 10:21 »
I just swapped to these ones, few people on here recommended them
http://m.ebay.co.uk/itm/120841859554?nav=SEARCH
Offline WadGTI
  • Golf GTI'er
« Reply #6 on: 28 May 2014, 10:22 »
I ran super's for about 6 months. Never had any miss fire issues and did go fine.
However, when I switched to NGK 7's...the power seems to be delivered better.
Offline davidgtrr34
« Reply #7 on: 28 May 2014, 17:11 »
im using denso pk20pr-p8 platinum plugs
Offline james2
  • No scammers please.
« Reply #8 on: 29 May 2014, 19:50 »
These are the best plug. Sod nology silver or denso  :sick:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 30 May 2014, 14:18 »
Meh NGK coppers do for me :whistle:
