Author Topic: steady revs but rough idle  (Read 5343 times)
Offline vwwvgolf
« on: 27 May 2014, 15:33 »
hello [people
 my abf will sometimes idle spot on at 900rpm and not move at all but the car seems to shudder and seems as if its idling roughly.
other times there is no issue what so ever.
 is this the ISV??
its not bad (yet) but just wanna know what could be wrong or going wrong
thanks
Offline snozan
Re: steady revs but rough idle
« Reply #1 on: 27 May 2014, 17:35 »
hello [people
 is this the ISV??
thanks
With or without AC?
Golf MK3 GTI 16v Colour Concept - Bumble bee Edition '96
Offline vwwvgolf
« Reply #2 on: 27 May 2014, 17:38 »
no A/C
Offline RadoABF
« Reply #3 on: 29 May 2014, 15:19 »
I would give the isv a clean mate, take off the hose, undo the Allen bolt holding it on and pull out, clean thoroughly with carb cleaner, if you can leave it connected up and clean with it buzzing away so it's more effective
Offline andy_k
« Reply #4 on: 29 May 2014, 20:47 »
I'd run a bottle of injector cleaner fluid through as well
Offline vwwvgolf
« Reply #5 on: 30 May 2014, 18:52 »
cheers guys, ill try it over weekend  :smiley:
Offline itavaltalainen
« Reply #6 on: 30 May 2014, 19:23 »
what engine (code please) have you got?
1.8 aam, abs, adz are notorious for having broken gears on throttle idle mechanism... which would give you exactly the symptoms you have now
Offline snozan
« Reply #7 on: 30 May 2014, 19:39 »
I guess ABF
Quote
« Reply #8 on: 30 May 2014, 19:54 »
d'oh... yeah i'd go ISV then.... other option would be potentiometer on throttle but that'd cause otehr issues too
Offline snozan
« Reply #9 on: 30 May 2014, 19:56 »
You could do a quick check to see if your switch for throttle valve is working properly. Its a basic open/close switch, check with a multimeter. If that one is broken you can get strange idle. Since it tells when the throttle is shut and when to idle.
If it's broken you might have a problem since the dealer canceled them 2007 - But i've come to understand, UK is where the ABF parts are :D
