Golf mk4
Wazzzer
Short shift option for AGU
Topic: Short shift option for AGU (Read 2355 times)
paultownsend
26 May 2014, 12:35 »
Gents. What are the Short shift options for AGU?
I believe it uses the same tower and shifter cable ends as a mk3? And can't use the usual TT shifter?
Any ideas?
northeast_gti-t
Serious forum addict
"1.8T AGU"
Re: Short shift option for AGU
26 May 2014, 13:52 »
the Agu uses the same gearbox as its aum twin so has cable operated mechanism with plastic clips etc a tt short shift can be used
2000 Mkiv GTi 1.8T AGU
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
26 May 2014, 17:00 »
The early ones have the same mech as the Mk3 but later have the same as the rest of the Mk4 range (which my '99 AGU has. I've used an ebay kit which is a direct copy of the B&M kit as works very well and only costs just over £30
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
rockmonkey69
26 May 2014, 17:33 »
I use dieselgeek's sigma 5 short shifter, it does away with the cable ends and clamps onto the threaded end of the cable, so it might work with yours too.
paultownsend
26 May 2014, 23:20 »
Gosh that sigma 5 is expensive!
Wazzer, is yours the one that replaces the whole gear stick?
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
27 May 2014, 17:15 »
yes it is mate, converts it from push down to lift up reverse as well
dom
10k hero
Back in a Mk4
Reply #6 on:
28 May 2014, 09:41 »
Quote from: Wazzzer on 27 May 2014, 17:15
Got a link to the one you bought?
Golf mk4
Wazzzer
